ONEX #54 Web Site
Date:  9-23-2013
Number of Hours:  0.50
Manual Reference:  C01
Brief Description:  Altrak pitch connection
Connected the Altrak control rod to the elevator idler arm. I still need to trim, drill and tap the forward end of the solenoid pushrod for the forward rod end when the solenoid is finally positioned.
Ordered a 4mm od x 1.7mm id right angle connector cable for the AV8OR power when installed in the Airgizmos mount.
Altrak rod end on the elevator idler arm
